spleenharvester
May 31, 2024Guide
Samba 4.1.17 for ReadyNAS Duo v1 (sparc) [Redux]
A while back another user here posted some very good instructions on how to enable SMB3 on the original Sparc-based ReadyNAS Duo units (mine is an RND2000). However, these have since stopped working ...
spleenharvester
Jun 01, 2024Guide
A few corrections because it won't let me edit the original post:
- Note that RAIDar 6 has a bug that makes it ignore the RAID version you select during initial setup and initialise with RAID1 anyway. Use RAIDar 4 instead. Once initialised after the factory reset double check in FrontView that it has actually chosen the RAID version you selected
- Before executing step 7 you have to create the directory /etc/appt/ using
mkdir /etc/appt
- In step 19 [YOURSERVER] should be the hostname, not the IP address. The value of 'Dialect' in the output should be 3.0.
saudade
Jun 01, 2024Apprentice
Thanks for this update!! I have a Duo V1 that serves as a backup NAS to my primary NAS. While I do sometimes connect to it directly from my Win11 desktop, it isn't often enough to warrant messing with it at the moment.
I have bookmarked this thread so I can get back to it quickly if/when I'm ready to make the jump.
Thanks Again!
