bc732
Nov 03, 2020Tutor
Samba 4.1.17 for ReadyNAS Duo v1 (sparc)
Hi all, I just picked one of these old guys up for super cheap. I kept finding posts where people were told that you couldn't get any newer versions of Samba on it, but I decided to try anyway. ...
Sandshark
Nov 04, 2020Sensei
If you have to "mess with" smb.conf and put things in it that the OS normally doesn't, then you could run into issues whever you do something that causes the NAS to re-write that. So, just keep an eye out that your changes stay changed.
bc732
Nov 04, 2020Tutor
Good call. Maybe add a separate config.
- SandsharkNov 04, 2020Sensei
I don't have a system runing OS 4.1.x, but I do have a 4.2.x and they tend to mostly follow the same strucure. Check /etc/samba/smb.conf to see if it contains the line include = /etc/frontview/samba/addons/addons.conf. If it does, put any additions or overrides (to anything above that include line, including what's included in Shares.conf) is addons.conf. It's purpose seems to be so apps can make changes to smb.conf without worry that the OS will overwrite them. FYI, OS6 also does this.
- bc732Nov 04, 2020Tutor
Nice! Thanks a lot.
Edit: and a warning for others. This version of Samba needs more memory, so you probably shouldn't try it without a memory upgrade.
- ClockedDec 04, 2020Guide
Great info! I have been running 512MB for years with this so I think I am good to go on trying this out.
I have SSH enabled and can use WinSCP to connect and run a terminal, but I am not a programmer and only know basic Linux. Can you give any more detail in regards to the comment by Sandshark in regards to the /etc/samba/smb.conf and the "include = /etc/frontview/samba/addons/addons.conf" specifics?
I am willing to try this only because I just bought & configured a new NAS and my ReadyNAS is sitting on the shelf. I would really like to resurect it!
