bc732
Nov 03, 2020Tutor
Samba 4.1.17 for ReadyNAS Duo v1 (sparc)
Hi all, I just picked one of these old guys up for super cheap. I kept finding posts where people were told that you couldn't get any newer versions of Samba on it, but I decided to try anyway. ...
MusicLover2112
Sep 08, 2022Initiate
I realize this is an old thread, but I recently fired up my old ReadyNAS NV and NV+ to locate some old data that I somehow never transferred to my newer NAS platform. Of course I discovered that I could not access the shares anymore due to the SMB version deprecation with Windows 11 (and 10) unless one enabled the antiquated SBMv1 with some potential security risk.
This obviously led me here but my Linux skills were quite minimal, so I knew I was in for some challenging times ahead. Here were my struggles so hopefully others can be assisted through the process (I used an Ubuntu 22.04 Linux container within Windows 11 to complete this task.):
Challenge 1: Realizing that Chrome and Edge blocked access TLS 1.0/1.1 so I needed to use Firefox and enable TLS 1.0 in the flags to gain access to the Frontview Admin interface.
Challenge 2: After installing the SSH and Apt add-ins and failing to access the ReadyNAS units due to algorithm errors. The first error complained about lacking a certain diffe-hellman-sha1...etc. so I added this following statement to the ssh config via this command:
sudo nano /etc/ssh/ssh_config
At the bottom I added:
KexAlgorithms diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
Then it complained about a sha1-rsa issue so I added another line below that in the ssh config:
HostKeyAlgorithms +ssh-rsa,ssh-dss
Challenge 3: Getting that darned .deb file onto the SSH root. That took me awhile to figure out, but here was the syntax that worked for me:
scp /home/user/Downloads/samba_4.1.17-1_sparc.deb root@ip address:/root
After all that the rest was simple - just follow bc732's awesome steps and you're golden. I did need to re-create my users as he mentioned but I was able to access the shares! My NV machine has 256MB RAM while my NV+ machine has 1GB RAM and the transfer rate improvements were 2-5MB/s write and 5-10MB/s read with the extra RAM. Not major but probably worth it, since overall the NV unit and Frontview interface are more responsive with the extra memory. Thanks again for the info, bc732, and the helpful discussion with the other folk here.
- SandsharkSep 09, 2022Sensei
This is all great stuff, but with each reply adding information, some less Linux savvy folks will have trouble following it. Since I don't have a 4.2.x system to do it on myself, I'm hoping that somebody who does it will create an updated "blow by blow" set of instructions that incorporates everything.
Better yet, of course, would be an add-on that does it all for you for owners not comfortable with SSH.
