LrdShaper
Jun 04, 2008Aspirant
Securely access your Bittorent Client from anywhere
This tip attempts to give a step by step guide to access your Bittorent client securely from anywhere (internet connection is a must of course) As with my previous guides this assumes that: 1) You...
LrdShaper
Jun 05, 2008Aspirant
ric3125 wrote: Her is mine.
blackbox:~/.ssh# ls
authorized_keys
blackbox:~/.ssh# pwd
/root/.ssh
blackbox:~/.ssh#
Did you change the permission on your .ssh directory and authorized_keys file?
root@Matthew~# ls -ld .ssh
drwx------ 2 root root 4096 Mar 13 17:25 .ssh
root@Matthew~# cd .ssh
root@Matthew~/.ssh# ls -l
total 8
-rw------- 1 root root 228 Oct 28 2007 authorized_keys
-rw-r--r-- 1 root root 1179 Apr 22 23:54 known_hosts
Did you copy the public key properly? If you changed the Key comment field in Puttygen the public key will change as well. Open up Puttygen, load your private key and copy the public key again into the authorized_keys file.
