LrdShaper
Jun 04, 2008Aspirant
Securely access your Bittorent Client from anywhere
This tip attempts to give a step by step guide to access your Bittorent client securely from anywhere (internet connection is a must of course) As with my previous guides this assumes that: 1) You...
LrdShaper
Jun 14, 2008Aspirant
doc wrote: FYI guys, you don't need to set up SSH keys for this to work. If you add in the tunneling in putty, once you successfully connect and establish a SSH session, it will work no matter what use you are. I personally like using my password and not SSH keys, but that's the security guy in me!
Doc
Yup, SSH keys are not needed. But he was asking for a secure way to do it which is why we configured to ReadyNAS to accept only private keys :D
By the way I forgot to mention that if you want to use a different user you would need to edit /etc/passwd and change the default shell /bin/false to /bin/bash for that user. I'll update the 1st post. Thanks
