rzarx
Jun 27, 2011Aspirant
seedbox to readynas transfer - sftp
Hi, I have been trying to find a way to transfer from my seedbox to my readynas ultra without using my macbook pro. I have had limited success in the shell using scp commands. Has anyone written...
invader980
Aug 14, 2011Aspirant
So i found a semi work around ..... ajaxplorer lets u connect to ftp sites as a repository , you can then access ur seedbox threw that and copy files accross ....
issue:
1)Ssh not available ( php limitation seems a php pluglin modual :php ssh2 is not included in the plugin)
2)No idea of wats going on ... as the gui wasnt made for downloading it simply says ok moving ....... the end lol ( still dono if it actualy did)
any other suggestions or ideas ?
issue:
