Nightraider1
Jun 10, 2012Aspirant
Sickbeard & sabnzbd directories not visible
HI, I got a ReadyNAS RNDU2000, and installed Sickbeard & Sabnnzbd for automatic updates on my tv shows. Got it almost working, i need t edit the scripts in /c/.sickbeard/autoProcessTV Now my ...
Jun 10, 2012Guru - Experienced User
The leading "." in the folder name is a convention that the file is hidden. If you are accessing from a windows machine, you need to set your folder options to let you see hidden files.
This is a Windows explorer option, not something you set on the NAS.
Though you should be able to enter "NasName\\c\.sickbeard\autoProcessTV" in the address bar of explorer and see the file contents. Explorer lets you enter the hidden file name in the address bar even if you can't see it.
