bseos
Jul 02, 2013Aspirant
Sabnzbd, Sickbeard, Python for OS6?
Just bought the Readynas 314 and was looking to get Sabnzbd and Sickbeard installed.
Are these addons available anywhere yet?
EDIT:
EDIT:
I was itching pretty bad for Sabnzbd and Sickbeard, and i just couldn't wait out any longer for the addons to be release so here's my guide on getting them installed on the new OS6 firmware. readynas.com/forum/viewtopic.php?f=36&t=71803
I myself have got a Readynas 314 and so far Sabnzbd and Sickbeard are working without a hitch.
- super_poussinVirtuosoDid you take a look on Genie Market or in the available apps under Apps menus (must be using 6.0.8)
you can also find some addons in my community dropboxYou can find all my addons in a drop box : https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC
If you don not have dropbox installed use this link to install it, so I will have more space to share addons : http://db.tt/v4mPZg7l - bseosAspirant
super-poussin wrote: Did you take a look on Genie Market or in the available apps under Apps menus (must be using 6.0.8)
Genie Market Does not have Sabnzbd or Sickbeard
I already checked out your addons, the only thing you have is Python.
Has anyone successfully gotton Sabnzbd or Sickbeard installed on OS 6?
I cant believe no ones mentioned this or provided a solution.. - super_poussinVirtuoso
bseos wrote: super-poussin wrote: Did you take a look on Genie Market or in the available apps under Apps menus (must be using 6.0.8)
contact Whocares by PM - bseosAspirant
He hasn't been active in over a month here or over at his site over @ readynasxtras.com where I have already sent an email.
But thanks for the reply.. - bseosAspirant<Deleted>
- super_poussinVirtuosoWill put openvpn client addon on dropbox
- super_poussinVirtuosoBtw take a look again on genie store Whocares should have published apps
- bseosAspirantSorry for the mess. I deleted my erroneous code and pushed a working guide on getting Sabnzbd and Sickbeard installed and running here: http://www.readynas.com/forum/viewtopic.php?f=36&t=71803
- jasongrimmeAspirantGreat guide, I've followed it a couple of times, but other tinkering had led to need to rebuild my box.
when executing...
apt-get -qy install apt-utils nano dialog whiptail
I get...
Reading package lists...
Building dependency tree...
Package apt-utils is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package apt-utils has no installation candidate
nas-EA-8B-F6:~# apt-get -qy install apt-utils nano dialog whiptail
I'm sure I need to add a source, here is the /etc/apt/sources.lst file, should I just uncomment out the debian.org entry?
deb http://www.readynas.com/packages 4.2.24/
#deb http://archive.debian.org/debian etch main
