dchristey
Dec 05, 2011Aspirant
SickBeard 0.485.1 - Speed issues?
Hi, I have installed the excellent SickBeard add-on today and after configuration it seems to now be working how I need it to - all good so far. I did encounter an issue with not being able to v...
WhoCares_
Dec 05, 2011Mentor
The problem is most likely the CPU of the NV+. It's running at under 300MHz and has to interpret SickBeards Python code. That's why the web interface behaves sluggish, especially when loading big chunks of data like large pictures for the series. Same goes for loading external stuff off the hard disk like your logs. Nothing much that can be done about that I fear.
-Stefan
-Stefan
