dchristey
Dec 05, 2011Aspirant
SickBeard 0.485.1 - Speed issues?
Hi, I have installed the excellent SickBeard add-on today and after configuration it seems to now be working how I need it to - all good so far. I did encounter an issue with not being able to v...
WhoCares_
Dec 10, 2011Mentor
Could be memory related. If you have SSH access, you can run "top" on the command line and keep a close look at the used swap space when both apps are running.
-Stefan
-Stefan
