kidziti
Oct 10, 2011Aspirant
Solved? I fixed my empty shares folder with ReadyNAS Remote
I've been working far too long trying to fix this, but wanted to say what worked for me. Since there are so many different threads about the same issue, I wanted to begin a new one. If this works (o...
stanfrizz
Apr 21, 2012Aspirant
I am having the same problem. Additional info: In the window that opens I see the following:
User (myself) successfully loged on IP xxx.xxx.xxx.xxx
Then I usually see (nas-name on ip xxx.xxx.xxx.xyz) but not this morning
Then 'nas-name' is diconnected from network
NAS SHARED folder is empty.
Will try the green light trick on monday
