claykin
May 01, 2013Aspirant
Subsconic 4.7.04 is a disaster on NVX
Been trying to get Subsonic to work on an NVX. NVX originally had 4.2.20 on it. Installed Subsonic but web GUI would not launch. Checked \webroot\subsonic folder and found Java and other folders ...
gibxxi
Aug 21, 2013Guide
You could also use the "EJRE Installer" add-on that floating around somewhere (try a search or google it) and simply change the path to the destination folder where the EJRE Installer places the java folder. I don't need java as a system-wide addition, so it kept it local to the Subsonic webroot folder.
Nosmo_King
Nov 18, 2015Aspirant
I've upgraded Subsonic to v5.3 (build 4568 – October 24, 2015) on my ReadyNas NVX (with latest and final 4.2.28 firmware) and I'm trying to update the JRE installed a part of the previous Subsonic 4.7b3. I fould the EJRE installer as you suggested and followed the directions. I now have EJRE version ejdk1.8.0_65 installed (according to RAIDiator) but I don't know where it got put - assuming root somewhere but I can't find it. You suggested "simply change the path to the destination folder where the EJRE Installer places the java folder." How would I make that change (so EJRE installs inside the webroot/subsonic folder)? Alternatively, can I delete the jre1.6.0_20 folder and point subsonic to the new jre1.8.0_65? How would I configure that?
Appreciate any help you can provide (2 years after the last post). Thanks
