claykin
May 01, 2013Aspirant
Subsconic 4.7.04 is a disaster on NVX
Been trying to get Subsonic to work on an NVX. NVX originally had 4.2.20 on it. Installed Subsonic but web GUI would not launch. Checked \webroot\subsonic folder and found Java and other folders ...
gibxxi
May 10, 2013Guide
You might also want to turn on "Fast Access Mode" if it isn't already. I have a suspicion that files that are open / locked may cause issues when Subsonic scans them for info, and the fact that Subsonic is constantly scanning your music folder(s) if fast access mode is off may cause a permanent increase in memory usage, rather than a temporary hike you'd get with scanning at set intervals. I set mine to only update the library once per day at midnight. If I make any changes at other times I want to see reflected straight away, I do a manual refresh.
What makes me think Subsonic updates on the fly with Fast Access mode off is this note in the setting's explanation: "Note: Changes to files will only be visible after your media folders are scanned."
