PYarr
Mar 10, 2013Aspirant
Subsonic web interface not working
Hi, I have been having some issues getting the Subsonic v4.7.04 addon to run properly. Initially I had issues installing the addon via FrontView (it would just hang on the "loading" animation). I d...
mmckinney75
Jun 16, 2013Aspirant
I am having the same issue after having a HD failure and replacing with new HD and rebuilding ReadyNAS configuration. After activating in the WebUI, if you navigate back to the installed Add-ins, it doesnt show as enabled. I tried manually running the startup script manually but no success. Checked the log and it looks like the startup script references a JRE that wasnt installed by the normal upload/checkin via the WebUi.
zeus-nas:/c/webroot/subsonic# ./subsonic.sh
Started Subsonic [PID 4816, /c/webroot/subsonic/subsonic_sh.log]
zeus-nas:/c/webroot/subsonic# more subsonic_sh.log
./subsonic.sh: line 116: /c/webroot/subsonic/jre1.6.0_20/bin/java: No such file or directory
zeus-nas:/c/webroot/subsonic# ls -l
total 30740
-rw-r--r-- 1 root root 3072 2013-06-16 14:29 Getting Started.html
-rw-r--r-- 1 root root 35819 2013-06-16 14:29 LICENSE.TXT
-rw-r--r-- 1 root root 540 2013-06-16 14:29 README.TXT
-rwxr-xr-x 1 root root 1081 2013-06-16 14:29 subsonic.bat
-rw-r--r-- 1 root root 10801885 2013-06-16 14:29 subsonic-booter-jar-with-dependencies.jar
-rwxr-xr-x 1 root root 5105 2013-06-16 14:29 subsonic.sh
-rw-r--r-- 1 root root 93 2013-06-16 17:25 subsonic_sh.log
-rw-r--r-- 1 root root 20603945 2013-06-16 14:29 subsonic.war
drwxr-xr-x 2 root root 4096 2013-06-16 14:29 transcode
Removed subsonic in the WebUI and then attempted reinstall. It verified the file fine but then when installing it hangs (waited over 30 mins). WebUI essentially unresponsive without reloading from address bar. Now it shows as installed but not enabled. I remember this same behavior when initially trying the install but disregarded because I was doing alot of over things when doing that install (large data transfers, setting mounts, etc) and chalked it up to that. I tried enabling but same behavior. it acts like the install is probably getting hungup putting the java down after it puts down the subsonic files (just a guess).
I was able to go to the oracle site and download the missing jre and installed it to the location referenced aboved and was able to get subsonic started and it is usable. Only problem is the WebUI still shows it as disabled, so I am assuming its not going to start on its own the next time the device boots. Also, its saying on the devices that server is unlicensed and 30 days left. Anybody got any information on that?
total 30740
