PYarr
Mar 10, 2013Aspirant
Subsonic web interface not working
Hi, I have been having some issues getting the Subsonic v4.7.04 addon to run properly. Initially I had issues installing the addon via FrontView (it would just hang on the "loading" animation). I d...
gibxxi
Aug 21, 2013Guide
The 4.7.4 version of the addon doesn't seem to contain the jetty web server or JAVA components required for Subsonic to run. Either that, or they simply don't get installed. I don't know how this happened but if you compare the file sizes of the 4.7.4 version and the 2.0.0 version, the later one is roughly half the size. To get the latest version to work, install the 2.0.0 version, and install the 4.7.4 version OVER THE TOP without uninstalling the old one.
