PYarr
Mar 10, 2013Aspirant
Subsonic web interface not working
Hi, I have been having some issues getting the Subsonic v4.7.04 addon to run properly. Initially I had issues installing the addon via FrontView (it would just hang on the "loading" animation). I d...
gibxxi
Aug 28, 2013Guide
Additional Note: If anyone here having done the Manual Java Update is having issues with Subsonic shutting itself down and only "minor" errors appearing in the log (incorrect format art, etc.), then you might want to perform the above procedure with EJRE 1.6.0 (Update 38) instead depending on the Subsonic version installed.
Seems currently Subsonic 4.7 and 4.8 are not fully compatible with Java 1.7.0.
