nexus2
Apr 05, 2009Follower
Subversion ( SVN ) Add-on
Hello, Super-Poussin removed the SVN add-on and I was hoping someone (or Super-Poussin) could please update it and bring it back. What was outdated with the old one anyway? I ask because I really do...
Playjoy
Dec 14, 2009Aspirant
efalsken wrote: No, you're correct to use http. It dosn't support https out of the box. (hacking your apache configs its possible to add https)
Have you created a repository yet? Did you install the related http://www.readynas.com/forum/viewtopic.php?f=47&t=33339]WebSVN addon? Can you log in using that? Note that you can browse SVN (over http) using just a web browser too. It's useful for debugging sometimes. What error does it show?
On my ReadyNAS, I edited the apache conf file to grant access to an SVN group that I created, and then added users to that svn group. After adding the group (in frontview), edit /etc/frontview/apache/addons/SUBVERSION.conf and changeto
# Limit write permission to list of valid users.
<LimitExcept GET PROPFIND OPTIONS REPORT>
AuthType Basic
AuthName "ReadyNAS SVN"
Require valid-user
</LimitExcept># Limit write permission to list of valid users.Commenting out the LimitExcept lines is what blocks anonymous users.
#<LimitExcept GET PROPFIND OPTIONS REPORT>
AuthType Basic
Require group svnusers
#</LimitExcept>
I am very sorry, a bad case of case sensitivity caught me... :oops:
I am able now to update via my regular login, via http as well as https (can't remember fiddling that last in though).
WebSVN is installed, next time I'll use that first to troubleshoot, thanks for the tip! It doesn't give any errors when browsing via a webbrowser to the repository.
If I understand you correctly, commenting out those LimitExcept lines will make it impossible for anonymous users to read or write?
