JPHey
Sep 13, 2020Guide
Syncronizing keeps on forever.
Volume data is syncing. 32,4% complete. Stays "stuck" at this percentage for the second day. RN 212 , two disks, health excellent, firmware 6.10.3 Please advise JPHey
- Sep 14, 2020
JPHey wrote:
A possible "overflow" of data on the NAS seems to have trigged the alerts and possibly initiated the resyncronizing. On the log zip file I find a message stating that "Volume less than 10% of capacity" with instructions to add or reduce. I have now deleted old files not important and now 45% of the volume is free.
If the data volume gets too full, the system will automatically start deleting snapshots. However, that shouldn't trigger a resync, so there is mystery here.
JPHey wrote:
While only 34% was resyncronized two days ago, this morning 82% is syncronized. I hope it speeds up and that the NAS again works okay with full performance and adm.responsiveness regained.
It should. Though you should probably run balance from the volume settings wheel. That will reduce performance while it are running, but I think it would be a good idea to run it. The longer it takes, the more it is needed. You might want to schedule the maintenance functions to run periodically (I run each every three months on a staggered schedule).
JPHey
Sep 13, 2020Guide
Thanks for responding swiftly.
No, i do NOT know why it is resyncing....
My two discs are both WDC . WD2 OEFRX (SATA 2TB), both healthy and active, it seems.
I find no error in the log, except "alert message failed to send".
The NAS works very very slow indeed, takes forever to log in adm., and seems more or less stuck-
I enclose the system logs
Thanks,
JPHey
Sep 13, 2020Guru - Experienced User
Just guessing, but it might have been a power interruption or unclean shutdown, since there is no shutdown message at 12 pm, just the startup.
FWIW, you'll find a lot more information if you download the log zip file.
- JPHeySep 13, 2020Guide
You may be on the right track.
The log file informs that the sending of system alerts have failed. (error code 500801001). The email alert contact set up had ceased to work and is now replaced with a gmail account, now tested.
Does this make sense to you?
Thanks,
- JPHeySep 14, 2020Guide
Additional info
I made a second diagnosis and found that
"Volume 1 is inactive" , however "No errors found"
Contradictive?
Please find enclosed in PDF the diagnostics "pop up"
JP
After restart
- StephenBSep 14, 2020Guru - Experienced User
Thanks again. Syncronization now is finally completed.
I did then, as suggested; ran the "balance" from the volume setting wheel, a rather fast process for once.
Mystery not solved, however my NAS now seems to run as expected. ;-)
Thanks for listening and giving a hand.
