greee
Jan 10, 2013Aspirant
teaming on ReadyNAS Pro Pioneer Edition 4.2.22 ?
Does anyone tried super-poussin old add-on to add teaming of the 2 ethernet link on a NVX PP with radiator version 4.2.22 ?
(available here viewtopic.php?f=48&t=34262&hilit=team+addon)
I just upload it and install it but on frontview / installed modules it is written "Only for use With Pioneer using 4.2.7 to 4.2.11"
So, I'm not confident to enable it...
Please some help / advice ?
Thank you.
Thank you.
This is an old thread, and the reference is older still. The forum was migrated last summer, and some of the ancient history is archived, and no longer generally accessible.
A direct link to the add-on is here: http://www.readynas.com/contributed/super-poussin/PRO-Team_2.1.bin
I don't use it (my pro-6 has teaming included), but my guess is that it still works.
- mdgm-ntgrNETGEAR Employee RetiredIt should work fine. Worked fine for me on an Ultra 6. Should work fine on any firmware 4.2.7 or newer.
- DaHotmailerAspirant
Should it also work on RAIDiator 4.2.28 as well?
And on top of that, when trying to enter the page: http://www.readynas.com/forum/viewtopic.php?f=48&t=34262&hilit=team+addon I get the message "Access Denied".
Is there some way I can get a hold of this add-on? Since a couple of days I had bought a smart-switch especially for this feature.
Thanks in advance!
