markg1
Aug 16, 2010Aspirant
TeamSpeak 3 for the x86 platform (ReadyNAS Pro/NVX)
TeamSpeak is flexible, powerful, scalable software which enables people to speak with one another over the Internet. TeamSpeak is FREE of charge for non-commercial use. you can have up to 512 users!...
markg1
Aug 15, 2011Aspirant
jamestx10 wrote: I would guess that the initial setup of the TS server is the hard part. This would be a really awesome add on though. Maybe Super will get a second wind on it or someone else will pick it up.
teamspeak 3 is a pretty easy install, at least on a normal server. And ALL of the server options/settings/etc. are done remotely via either the client or telnet. Nothing is done using the console.
all you do is copy the server files to a directory (any directory) and launch the program. it is all self contained and needs no outside resources that im aware of.
the only problem is that the initial launch tells you the admin password on the console, and you might not have console access on some installs, but the easy way around that is to launch once on your desktop computer, copy the password, then move the files elsewhere. thats what i have done on mine, and ive moved the software (including database) between at least 4 different servers over the last several months.
if you do what i describe, then all you need to do is copy the directory/files over to the readynas, and set up a cron job to start the executable on server start. so maybe we dont need an install, just some linux knowledge/how to do this on a readynas?
mark
