markg1
Aug 16, 2010Aspirant
TeamSpeak 3 for the x86 platform (ReadyNAS Pro/NVX)
TeamSpeak is flexible, powerful, scalable software which enables people to speak with one another over the Internet. TeamSpeak is FREE of charge for non-commercial use. you can have up to 512 users!...
diablo668
Sep 01, 2012Aspirant
I'm gonna bump this thread since I'm also looking into this and this is what I got so far:
F.Y.I. I'm running an Ultra 4 (x86) RAIDiator 4.2.19, keep in mind that Teamspeak will not run on a Sparc or ARM based device.
- Created a user 'Teamspeak' using the webinterface .
- Downloaded the current version: teamspeak3-server_linux-amd64-3.0.6.1.tar.gz <- Yes AMD64, turns out it's 64bit, I checked using:
- Extracted the tar and gave ownership to the Teamspeak user
- Started using the follwing command so it would run under the Teamspeak user (all the user created using the webinterface have /bin/false and cannot logon using SSH)
Then it quits on me claiming it can't find a bunch of libraries and when I check the bin file for dependencies it gives me the following results:
When I check for the missing lib, I can find the all in /lib/ but not in /lib64/ which means the 64bit are not installed, problem is that firmware is still based on Debian Lenny and haven't been able to find the right lib to install because lenny is missing from both http://www.debian.org/distrib/packages and http://www.debian.org/distrib/archive. Installing newer versions fails because they depend on other lib that aren't updated and forcing an installation could possibly brick everything. So any suggestions would be helpfull.
uname -a
Linux NAS 2.6.37.6.RNx86_64.2.1 #1 SMP Mon Aug 15 16:19:41 PDT 2011 x86_64 GNU/Linux
/bin/su -s /bin/bash -c '/usr/local/src/teamspeak3-server_linux-amd64/ts3server_startscript.sh start' Teamspeak
ldd -d ts3server_linux_amd64
linux-vdso.so.1 => (0x00007fffcefff000)
libdl.so.2 => not found
librt.so.1 => not found
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f9d8cf66000)
libstdc++.so.6 => not found
libm.so.6 => not found
libgcc_s.so.1 => not found
libc.so.6 => /lib64/libc.so.6 (0x00007f9d8cbf5000)
/lib64/ld-linux-x86-64.so.2 (0x00007f9d8d182000)
