markg1
Aug 16, 2010Aspirant
TeamSpeak 3 for the x86 platform (ReadyNAS Pro/NVX)
TeamSpeak is flexible, powerful, scalable software which enables people to speak with one another over the Internet. TeamSpeak is FREE of charge for non-commercial use. you can have up to 512 users!...
diablo668
Sep 10, 2012Aspirant
Yes I did try the 32bit version and failed to start it, but I'm getting close, because I now know it's possible.
First off:
And when you try to run the ts3server_minimal_runscript.sh from a root user it works, but haven't gotten it to run from a normal user account. Even with the user having all the rights on the folder it cuts out on a few errors:
First off:
ldd -d ts3server_linux_x86
linux-gate.so.1 => (0xffffe000)
libdl.so.2 => /lib/libdl.so.2 (0xf7742000)
librt.so.1 => /lib/librt.so.1 (0xf7739000)
libpthread.so.0 => /lib/libpthread.so.0 (0xf7721000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xf762b000)
libm.so.6 => /lib/libm.so.6 (0xf7605000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf75f8000)
libc.so.6 => /lib/libc.so.6 (0xf74ba000)
/lib/ld-linux.so.2 (0xf774d000)
sh ts3server_minimal_runscript.sh
Do you have the right TS3 Server package for your system? You have: Linux x86_64, not Linux i386.
2012-09-10 18:48:53.181718|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6.1 (2012-06-29 07:59:05)
2012-09-10 18:48:53.182798|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
2012-09-10 18:48:53.182960|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
2012-09-10 18:48:53.183675|INFO |DatabaseQuery | | checking database integrity (may take a while)
2012-09-10 18:48:53.278025|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
2012-09-10 18:48:53.778699|ERROR |Accounting | | failed to register local accounting service
2012-09-10 18:48:53.778871|ERROR |ServerLibPriv | | Server() error while starting servermanager, error: instance check error
