Zuluf
May 21, 2014Aspirant
Tonido - turning off
Hi all, I'm new here. I'm having problems with Tonido. It keeps shutting off by itself. It happens in a few hours after I turn it back on in Raidar. I am using readynas ultra 2 and Raidar 4.3.8. ...
Zuluf
Log is 100 pages long. Here are just a few if somebody can help:
TONIDO_ITUNES_SYNC_PLAYLIST
18:42:44:626 [1] [AppStarter]:I: TONIDO_INDEXING_ENABLED = 1
18:42:44:626 [1] [AppStarter]:I: ---------------------------------
18:43:36:796 [6] [Dispatcher]:E: Token not found in List: bde24c3b-1f59-4e4d-8380-0b35c8a3dda5
18:50:10:895 [1] [AppStarter]:T: ***********STARTING*****TONIDO**********
18:50:10:895 [1] [AppStarter]:I: Tonido Working Directory: /usr/local/tonido
18:50:10:896 [1] [AppStarter]:I: Running on OS : Linux
18:50:10:896 [1] [AppStarter]:I: Running on OS Version : 2.6.37.6.RNx86_64.2.1
18:50:10:896 [1] [AppStarter]:I: Running on OS Arch : x86_64
18:50:10:896 [1] [AppStarter]:I: Running System Version : 4.79.0.26297
18:50:10:896 [1] [AppStarter]:I: Running Message Version : 0.0.0.1
18:50:10:896 [1] [AppStarter]:I: Built on : Mar 25 2014
18:50:10:896 [1] [AppStarter]:I: Using AppRoot : /c/home/tonido/tonido/data
18:50:10:896 [1] [AppStarter]:I: Host Name : nas-24-D4-22
18:50:10:897 [1] [AppStarter]:I: Using PeerDomain : tonidoid.com
18:50:10:897 [1] [AppStarter]:I: Using PluginListURL : http://patch.codelathe.com/tonido/live/pluginlist/x86-linux/pluginlist.xml
18:50:10:897 [1] [AppStarter]:I: [AppRoot ] = /c/home/tonido/tonido/data
18:50:10:897 [1] [AppStarter]:I: [DSBaseURL ] = https://s1.codelathe.com/api/ds/tonidods.php
18:50:10:897 [1] [AppStarter]:I: [DomainListURL ] = http://info.codelathe.com/domainlist/domainlist.xml
18:50:10:897 [1] [AppStarter]:I: [PluginListURL ] = http://patch.codelathe.com/tonido/live/pluginlist/x86-linux/pluginlist.xml
18:50:10:897 [1] [AppStarter]:I: [RSSURL ] = http://info.codelathe.com/news/rssfeed.xml
18:50:10:897 [1] [AppStarter]:I: [RelayServiceURL] = https://s1.codelathe.com/api/relay/getrelayall.php
18:50:10:897 [1] [AppStarter]:I: [UsageStatsURL ] = http://info.codelathe.com/stats/tonidousagestats.php
18:50:10:897 [1] [AppStarter]:I: [DefaultLanguage] = english
18:50:10:897 [1] [AppStarter]:I: [DomainServerPort] = 24465
18:50:10:897 [1] [AppStarter]:I: [EnableDNS ] = 0
18:50:10:898 [1] [AppStarter]:I: [EnableDomain ] = 0
18:50:10:898 [1] [AppStarter]:I: [EnableErrorLog ] = 1
18:50:10:898 [1] [AppStarter]:I: [HTTPProxyHost ] =
18:50:10:898 [1] [AppStarter]:I: [HTTPProxyPort ] = 80
18:50:10:898 [1] [AppStarter]:I: [HttpPort ] = 10001
18:50:10:898 [1] [AppStarter]:I: [KeepLog ] = 2 days
18:50:10:898 [1] [AppStarter]:I: [LAN_XFer_Size ] = 1024000
18:50:10:898 [1] [AppStarter]:I: [LogAsync ] = 1
18:50:10:898 [1] [AppStarter]:I: [LogLevel ] = error
18:50:10:898 [1] [AppStarter]:I: [MaxNetworkConnections] = 200
18:50:10:898 [1] [AppStarter]:I: [NetworkAccess ] = 1
18:50:10:898 [1] [AppStarter]:I: [NetworkInterface] = 0
18:50:10:898 [1] [AppStarter]:I: [PurgeCount ] = 5
18:50:10:898 [1] [AppStarter]:I: [RemoteAdmin ] = 1
18:50:10:898 [1] [AppStarter]:I: [UDPPort ] = 41940
18:50:10:898 [1] [AppStarter]:I: [WAN_LAN_Redirect] = 1
18:50:10:898 [1] [AppStarter]:I: [WAN_XFer_Size ] = 51200
18:50:10:898 [1] [AppStarter]:I: [WebAccess ] = all
18:50:10:898 [1] [AppStarter]:I: [Domain ] = tonidoid.com
18:50:10:898 [1] [AppStarter]:I: [ErrorLogRoot ] = /c/home/tonido/tonido/data/logs/errorlogs
18:50:10:898 [1] [AppStarter]:I: ---------------------------------
18:50:10:898 [1] [AppStarter]:I: TONIDO_LINUX
18:50:10:899 [1] [AppStarter]:I: DEFAULT_CHECK_UPDATE_INTERVAL = 30 * 24
18:50:10:899 [1] [AppStarter]:I: DEFAULT_WEBUI_LANGUAGE = "english"
18:50:10:899 [1] [AppStarter]:I: DEFAULT_KEEP_LOG = "1 days"
18:50:10:899 [1] [AppStarter]:I: DEFAULT_EXPLORER_BIT_RATE = "64"
18:50:10:899 [1] [AppStarter]:I: DEFAULT_ALLOW_REMOTE_ADMIN = false
18:50:10:899 [1] [AppStarter]:I: TONIDO_USE_OEM_TAG = ""
18:50:10:899 [1] [AppStarter]:I: TONIDO_MIN_PASSWORD_STRENGTH = 8
18:50:10:899 [1] [AppStarter]:I: TONIDO_USE_PRODUCT_NAME = "Tonido"
18:50:10:899 [1] [AppStarter]:I: TONIDO_USE_PRODUCT_WEBSITE = "http://www.tonido.com"
18:50:10:899 [1] [AppStarter]:I: TONIDO_USE_COMPANY_NAME = "CodeLathe"
18:50:10:899 [1] [AppStarter]:I: DS_UPDATE_INTERVAL = 6 * 60
18:50:10:899 [1] [AppStarter]:I: USE_FASTJPEG_IMAGE_RESIZE = 1
18:50:10:899 [1] [AppStarter]:I: TONIDO_HAS_INT64 = TONIDO_HAS_INT64
18:50:10:899 [1] [AppStarter]:I: TONIDO_SYNCSTOREDATA_NAME = "TonidoSyncData"
18:50:10:899 [1] [AppStarter]:I: TONIDO_SYNCUSERDATA_NAME = "TonidoSync"
18:50:10:899 [1] [AppStarter]:I: TONIDO_SYNC_UPDATE_URL = "http://patch.codelathe.com/tonidosync/live/tonidosyncversion.xml"
18:50:10:899 [1] [AppStarter]:I: TONIDO_TONIDOPRO_NAME = "Tonido"
18:50:10:899 [1] [AppStarter]:I: TONIDO_WIN32_NAMED_MUTEX = "TonidoApplicationMutex"
18:50:10:899 [1] [AppStarter]:I: TONIDO_APPROOT_DIRECTORY_NAME = "tonido"
18:50:10:899 [1] [AppStarter]:I: TONIDO_WEBSHARE_CUSTOM_ADDITIONAL_FOOTER = ""
18:50:10:899 [1] [AppStarter]:I: TONIDO_DEVICE_NAME = "COMPUTER";
18:50:10:899 [1] [AppStarter]:I: TONIDO_NO_HINT_REMOTE = 1
18:50:10:899 [1] [AppStarter]:I: TONIDO_SHOW_DESKTOP_AS_ROOTS = 1
18:50:10:899 [1] [AppStarter]:I: TONIDO_SHOW_MACID_IN_LOG = TONIDO_SHOW_MACID_IN_LOG
18:50:10:899 [1] [AppStarter]:I: TONIDO_NO_PROCESS_FILE_LOCK = TONIDO_NO_PROCESS_FILE_LOCK
18:50:10:900 [1] [AppStarter]:I: TONIDO_SUICIDE_ON_SHUTDOWN = TONIDO_SUICIDE_ON_SHUTDOWN
18:50:10:900 [1] [AppStarter]:I: TONIDO_NO_ATOMIC_INCREMENT = TONIDO_NO_ATOMIC_INCREMENT
18:50:10:900 [1] [AppStarter]:I: TONIDO_HTTP_ACCESS_ALL = TONIDO_HTTP_ACCESS_ALL
18:50:10:900 [1] [AppStarter]:I: TONIDO_SET_MOUNTEDDRIVEPATH_USERDATA = TONIDO_SET_MOUNTEDDRIVEPATH_USERDATA
18:50:10:900 [1] [AppStarter]:I: TONIDO_MOUNTEDPATH_USERDATA = TONIDO_MOUNTEDPATH_USERDATA
18:50:10:900 [1] [AppStarter]:I: TONIDO_SAVE_PASSWORD = TONIDO_SAVE_PASSWORD
18:50:10:900 [1] [AppStarter]:I: TONIDO_CHECK_FREESPACE_BEFORE_UPDATE = TONIDO_CHECK_FREESPACE_BEFORE_UPDATE
18:50:10:900 [1] [AppStarter]:I: TONIDO_ALLOW_REMOTEADMIN_NO_PROFILE = TONIDO_ALLOW_REMOTEADMIN_NO_PROFILE
18:50:10:900 [1] [AppStarter]:I: TONIDO_ALLOW_REMOTEADMIN_DEFAULT = TONIDO_ALLOW_REMOTEADMIN_DEFAULT
18:50:10:900 [1] [AppStarter]:I: TONIDO_SHOW_MOUNTED_USBDRIVES_AS_ROOTS = TONIDO_SHOW_MOUNTED_USBDRIVES_AS_ROOTS
18:50:10:900 [1] [AppStarter]:I: TONIDO_CUSTOM_MHTONS = TONIDO_CUSTOM_MHTONS
18:50:10:900 [1] [AppStarter]:I: TONIDO_LOW_POWER_CPU = TONIDO_LOW_POWER_CPU
18:50:10:900 [1] [AppStarter]:I: TONIDO_SINGLE_TRANSCODING_PROCESS = TONIDO_SINGLE_TRANSCODING_PROCESS
18:50:10:900 [1] [AppStarter]:I: TONIDO_REQUIRE_PLUGADMIN_PWDCHANGE = TONIDO_REQUIRE_PLUGADMIN_PWDCHANGE
18:50:10:900 [1] [AppStarter]:I: TONIDO_REQUIRE_VERIFY_LICENSE = TONIDO_REQUIRE_VERIFY_LICENSE
18:50:10:900 [1] [AppStarter]:I: TONIDO_FREE_WEBSHARE_PRO = TONIDO_FREE_WEBSHARE_PRO
18:50:10:900 [1] [AppStarter]:I: TONIDO_FREE_DLNA = TONIDO_FREE_DLNA
18:50:10:900 [1] [AppStarter]:I: TONIDO_READ_DISKUSAGE_PERIODIC = TONIDO_READ_DISKUSAGE_PERIODIC
18:50:10:900 [1] [AppStarter]:I: TONIDO_EMBEDDED_DEVICE = TONIDO_EMBEDDED_DEVICE
18:50:10:900 [1] [AppStarter]:I: TONIDO_LOAD_ADMINPLUGIN = TONIDO_LOAD_ADMINPLUGIN
18:50:10:900 [1] [AppStarter]:I: TONIDO_ALLOW_GUEST_PROFILE_ACCESS = TONIDO_ALLOW_GUEST_PROFILE_ACCESS
18:50:10:901 [1] [AppStarter]:I: TONIDO_ENABLE_OPENID_LOGIN = TONIDO_ENABLE_OPENID_LOGIN
18:50:10:901 [1] [AppStarter]:I: TONIDO_USE_UNIVERSAL_FILE_MONITOR = TONIDO_USE_UNIVERSAL_FILE_MONITOR
18:50:10:901 [1] [AppStarter]:I: TONIDO_ENABLE_SINGLE_CACHE_DB = TONIDO_ENABLE_SINGLE_CACHE_DB
18:50:10:901 [1] [AppStarter]:I: TONIDO_USE_CUSTOM_NETWORK_NAME = TONIDO_USE_CUSTOM_NETWORK_NAME
18:50:10:901 [1] [AppStarter]:I: TONIDO_ALLOW_NEWACCOUNT_RECOVERY = TONIDO_ALLOW_NEWACCOUNT_RECOVERY
18:50:10:901 [1] [AppStarter]:I: TONIDO_SET_CUSTOM_FILE_PERMISSIONS = TONIDO_SET_CUSTOM_FILE_PERMISSIONS
18:50:10:901 [1] [AppStarter]:I: TONIDO_CUSTOM_FILE_PERMISSIONS_USER = TONIDO_CUSTOM_FILE_PERMISSIONS_USER
18:50:10:901 [1] [AppStarter]:I: TONIDO_CUSTOM_FILE_PERMISSIONS_GROUP = TONIDO_CUSTOM_FILE_PERMISSIONS_GROUP
18:50:10:901 [1] [AppStarter]:I: TONIDO_NO_LOCAL_ROOTS = TONIDO_NO_LOCAL_ROOTS
18:50:10:901 [1] [AppStarter]:I: TONIDO_DISABLE_RELAY_IF_INACTIVE = TONIDO_DISABLE_RELAY_IF_INACTIVE
18:50:10:901 [1] [AppStarter]:I: TONIDO_USE_RELAY_INACTIVEHOURS = TONIDO_USE_RELAY_INACTIVEHOURS
18:50:10:901 [1] [AppStarter]:I: TONIDO_DISALLOW_GUEST_MANAGEMENT = TONIDO_DISALLOW_GUEST_MANAGEMENT
18:50:10:901 [1] [AppStarter]:I: TONIDO_EXTERNAL_GUEST_ACCOUNTS = TONIDO_EXTERNAL_GUEST_ACCOUNTS
18:50:10:901 [1] [AppStarter]:I: TONIDO_GENERATE_ROOT_LIST_XML = TONIDO_GENERATE_ROOT_LIST_XML
18:50:10:901 [1] [AppStarter]:I: TONIDO_EXTERNAL_SHARES_OEM1 = TONIDO_EXTERNAL_SHARES_OEM1
18:50:10:901 [1] [AppStarter]:I: TONIDO_EXTRA_PATH_FILTER = TONIDO_EXTRA_PATH_FILTER
18:50:10:901 [1] [AppStarter]:I: TONIDO_STARTUP_INIT_OEM1 = TONIDO_STARTUP_INIT_OEM1
18:50:10:901 [1] [AppStarter]:I: TONIDO_TONIDOPRO_NAME = "Tonido"
18:50:10:901 [1] [AppStarter]:I: TONIDO_NO_WSTRING = TONIDO_NO_WSTRING
18:50:10:901 [1] [AppStarter]:I: TONIDO_NO_MP3_TRANSCODING = TONIDO_NO_MP3_TRANSCODING
18:50:10:901 [1] [AppStarter]:I: TONIDO_NO_INOTIFY = TONIDO_NO_INOTIFY
18:50:10:902 [1] [AppStarter]:I: TONIDO_NO_SIGNAL_HANDLER = TONIDO_NO_SIGNAL_HANDLER
18:50:10:902 [1] [AppStarter]:I: TONIDO_ALLOW_LOGIN_WITH_OEMTOKEN = TONIDO_ALLOW_LOGIN_WITH_OEMTOKEN
18:50:10:902 [1] [AppStarter]:I: TONIDO_ALLOW_GUESTMANAGEMENT_LOCAL = TONIDO_ALLOW_GUESTMANAGEMENT_LOCAL
18:50:10:902 [1] [AppStarter]:I: TONIDO_ALLOW_CURRENTPROFILE_DELETE = TONIDO_ALLOW_CURRENTPROFILE_DELETE
18:50:10:902 [1] [AppStarter]:I: TONIDO_NO_CRYPTOPP = TONIDO_NO_CRYPTOPP
18:50:10:902 [1] [AppStarter]:I: TONIDO_MONIT_HDDTEMP_PERIODIC = TONIDO_MONIT_HDDTEMP_PERIODIC
18:50:10:902 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIAALBUMART = 1
18:50:10:902 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIAMETADATA = 1
18:50:10:902 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIAMETADATA_DURATION = TONIDO_ENABLE_MEDIAMETADATA_DURATION
18:50:10:902 [1] [AppStarter]:I: TONIDO_ENABLE_EDITMODE_SUPPORT = TONIDO_ENABLE_EDITMODE_SUPPORT
18:50:10:902 [1] [AppStarter]:I: TONIDO_ENABLE_POPEN_PROCESS_SUPPORT = TONIDO_ENABLE_POPEN_PROCESS_SUPPORT
18:50:10:902 [1] [AppStarter]:I: TONIDO_PREPARE_VIDEO = 1
18:50:10:902 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIASCREENSHOT = 1
18:50:10:902 [1] [AppStarter]:I: TONIDO_ITUNES_SYNC_PLAYLIST = TONIDO_ITUNES_SYNC_PLAYLIST
18:50:10:902 [1] [AppStarter]:I: TONIDO_INDEXING_ENABLED = 1
18:50:10:902 [1] [AppStarter]:I: ---------------------------------
18:50:10:958 [1] [AppStarter]:E: Unable to lock file. Check if another process is already running
18:50:11:159 [3] [Dispatcher]:E: No Message Handler Found For EventNotifierService for operation SIGNALEVENT
18:50:11:160 [3] [Dispatcher]:E: No Message Handler Found For EventNotifierService for operation SIGNALEVENT
18:50:12:161 [0] []:E: PluginManager: Plugin Stop for unknown plugin
18:57:18:357 [6] [Dispatcher]:E: Token not found in List: 1b765a08-db80-4360-8938-cb579f76dd79
18:58:03:881 [6] [Dispatcher]:E: Token not found in List: 1aa44ae0-f6e1-401b-82cb-03235b15f006
18:58:37:032 [6] [Dispatcher]:E: Token not found in List: 989b2584-7f43-4b2a-8d3d-dcea5b9714db
19:14:03:003 [1] [AppStarter]:T: ***********STARTING*****TONIDO**********
19:14:03:003 [1] [AppStarter]:I: Tonido Working Directory: /usr/local/tonido
19:14:03:003 [1] [AppStarter]:I: Running on OS : Linux
19:14:03:003 [1] [AppStarter]:I: Running on OS Version : 2.6.37.6.RNx86_64.2.1
19:14:03:004 [1] [AppStarter]:I: Running on OS Arch : x86_64
19:14:03:004 [1] [AppStarter]:I: Running System Version : 4.79.0.26297
19:14:03:004 [1] [AppStarter]:I: Running Message Version : 0.0.0.1
19:14:03:004 [1] [AppStarter]:I: Built on : Mar 25 2014
19:14:03:004 [1] [AppStarter]:I: Using AppRoot : /c/home/tonido/tonido/data
19:14:03:004 [1] [AppStarter]:I: Host Name : nas-24-D4-22
19:14:03:005 [1] [AppStarter]:I: Using PeerDomain : tonidoid.com
19:14:03:005 [1] [AppStarter]:I: Using PluginListURL : http://patch.codelathe.com/tonido/live/pluginlist/x86-linux/pluginlist.xml
19:14:03:005 [1] [AppStarter]:I: [AppRoot ] = /c/home/tonido/tonido/data
19:14:03:005 [1] [AppStarter]:I: [DSBaseURL ] = https://s1.codelathe.com/api/ds/tonidods.php
19:14:03:005 [1] [AppStarter]:I: [DomainListURL ] = http://info.codelathe.com/domainlist/domainlist.xml
19:14:03:005 [1] [AppStarter]:I: [PluginListURL ] = http://patch.codelathe.com/tonido/live/pluginlist/x86-linux/pluginlist.xml
19:14:03:005 [1] [AppStarter]:I: [RSSURL ] = http://info.codelathe.com/news/rssfeed.xml
19:14:03:005 [1] [AppStarter]:I: [RelayServiceURL] = https://s1.codelathe.com/api/relay/getrelayall.php
19:14:03:005 [1] [AppStarter]:I: [UsageStatsURL ] = http://info.codelathe.com/stats/tonidousagestats.php
19:14:03:005 [1] [AppStarter]:I: [DefaultLanguage] = english
19:14:03:006 [1] [AppStarter]:I: [DomainServerPort] = 24465
19:14:03:006 [1] [AppStarter]:I: [EnableDNS ] = 0
19:14:03:006 [1] [AppStarter]:I: [EnableDomain ] = 0
19:14:03:006 [1] [AppStarter]:I: [EnableErrorLog ] = 1
19:14:03:006 [1] [AppStarter]:I: [HTTPProxyHost ] =
19:14:03:006 [1] [AppStarter]:I: [HTTPProxyPort ] = 80
19:14:03:006 [1] [AppStarter]:I: [HttpPort ] = 10001
19:14:03:006 [1] [AppStarter]:I: [KeepLog ] = 2 days
19:14:03:006 [1] [AppStarter]:I: [LAN_XFer_Size ] = 1024000
19:14:03:006 [1] [AppStarter]:I: [LogAsync ] = 1
19:14:03:006 [1] [AppStarter]:I: [LogLevel ] = error
19:14:03:006 [1] [AppStarter]:I: [MaxNetworkConnections] = 200
19:14:03:006 [1] [AppStarter]:I: [NetworkAccess ] = 1
19:14:03:006 [1] [AppStarter]:I: [NetworkInterface] = 0
19:14:03:006 [1] [AppStarter]:I: [PurgeCount ] = 5
19:14:03:007 [1] [AppStarter]:I: [RemoteAdmin ] = 1
19:14:03:007 [1] [AppStarter]:I: [UDPPort ] = 41940
19:14:03:007 [1] [AppStarter]:I: [WAN_LAN_Redirect] = 1
19:14:03:007 [1] [AppStarter]:I: [WAN_XFer_Size ] = 51200
19:14:03:007 [1] [AppStarter]:I: [WebAccess ] = all
19:14:03:007 [1] [AppStarter]:I: [Domain ] = tonidoid.com
19:14:03:007 [1] [AppStarter]:I: [ErrorLogRoot ] = /c/home/tonido/tonido/data/logs/errorlogs
19:14:03:007 [1] [AppStarter]:I: ---------------------------------
19:14:03:007 [1] [AppStarter]:I: TONIDO_LINUX
19:14:03:007 [1] [AppStarter]:I: DEFAULT_CHECK_UPDATE_INTERVAL = 30 * 24
19:14:03:007 [1] [AppStarter]:I: DEFAULT_WEBUI_LANGUAGE = "english"
19:14:03:007 [1] [AppStarter]:I: DEFAULT_KEEP_LOG = "1 days"
19:14:03:007 [1] [AppStarter]:I: DEFAULT_EXPLORER_BIT_RATE = "64"
19:14:03:007 [1] [AppStarter]:I: DEFAULT_ALLOW_REMOTE_ADMIN = false
19:14:03:007 [1] [AppStarter]:I: TONIDO_USE_OEM_TAG = ""
19:14:03:007 [1] [AppStarter]:I: TONIDO_MIN_PASSWORD_STRENGTH = 8
19:14:03:008 [1] [AppStarter]:I: TONIDO_USE_PRODUCT_NAME = "Tonido"
19:14:03:008 [1] [AppStarter]:I: TONIDO_USE_PRODUCT_WEBSITE = "http://www.tonido.com"
19:14:03:008 [1] [AppStarter]:I: TONIDO_USE_COMPANY_NAME = "CodeLathe"
19:14:03:008 [1] [AppStarter]:I: DS_UPDATE_INTERVAL = 6 * 60
19:14:03:008 [1] [AppStarter]:I: USE_FASTJPEG_IMAGE_RESIZE = 1
19:14:03:008 [1] [AppStarter]:I: TONIDO_HAS_INT64 = TONIDO_HAS_INT64
19:14:03:008 [1] [AppStarter]:I: TONIDO_SYNCSTOREDATA_NAME = "TonidoSyncData"
19:14:03:008 [1] [AppStarter]:I: TONIDO_SYNCUSERDATA_NAME = "TonidoSync"
19:14:03:008 [1] [AppStarter]:I: TONIDO_SYNC_UPDATE_URL = "http://patch.codelathe.com/tonidosync/live/tonidosyncversion.xml"
19:14:03:008 [1] [AppStarter]:I: TONIDO_TONIDOPRO_NAME = "Tonido"
19:14:03:008 [1] [AppStarter]:I: TONIDO_WIN32_NAMED_MUTEX = "TonidoApplicationMutex"
19:14:03:008 [1] [AppStarter]:I: TONIDO_APPROOT_DIRECTORY_NAME = "tonido"
19:14:03:008 [1] [AppStarter]:I: TONIDO_WEBSHARE_CUSTOM_ADDITIONAL_FOOTER = ""
19:14:03:008 [1] [AppStarter]:I: TONIDO_DEVICE_NAME = "COMPUTER";
19:14:03:008 [1] [AppStarter]:I: TONIDO_NO_HINT_REMOTE = 1
19:14:03:008 [1] [AppStarter]:I: TONIDO_SHOW_DESKTOP_AS_ROOTS = 1
19:14:03:008 [1] [AppStarter]:I: TONIDO_SHOW_MACID_IN_LOG = TONIDO_SHOW_MACID_IN_LOG
19:14:03:008 [1] [AppStarter]:I: TONIDO_NO_PROCESS_FILE_LOCK = TONIDO_NO_PROCESS_FILE_LOCK
19:14:03:009 [1] [AppStarter]:I: TONIDO_SUICIDE_ON_SHUTDOWN = TONIDO_SUICIDE_ON_SHUTDOWN
19:14:03:009 [1] [AppStarter]:I: TONIDO_NO_ATOMIC_INCREMENT = TONIDO_NO_ATOMIC_INCREMENT
19:14:03:009 [1] [AppStarter]:I: TONIDO_HTTP_ACCESS_ALL = TONIDO_HTTP_ACCESS_ALL
19:14:03:009 [1] [AppStarter]:I: TONIDO_SET_MOUNTEDDRIVEPATH_USERDATA = TONIDO_SET_MOUNTEDDRIVEPATH_USERDATA
19:14:03:009 [1] [AppStarter]:I: TONIDO_MOUNTEDPATH_USERDATA = TONIDO_MOUNTEDPATH_USERDATA
19:14:03:009 [1] [AppStarter]:I: TONIDO_SAVE_PASSWORD = TONIDO_SAVE_PASSWORD
19:14:03:009 [1] [AppStarter]:I: TONIDO_CHECK_FREESPACE_BEFORE_UPDATE = TONIDO_CHECK_FREESPACE_BEFORE_UPDATE
19:14:03:009 [1] [AppStarter]:I: TONIDO_ALLOW_REMOTEADMIN_NO_PROFILE = TONIDO_ALLOW_REMOTEADMIN_NO_PROFILE
19:14:03:009 [1] [AppStarter]:I: TONIDO_ALLOW_REMOTEADMIN_DEFAULT = TONIDO_ALLOW_REMOTEADMIN_DEFAULT
19:14:03:009 [1] [AppStarter]:I: TONIDO_SHOW_MOUNTED_USBDRIVES_AS_ROOTS = TONIDO_SHOW_MOUNTED_USBDRIVES_AS_ROOTS
19:14:03:009 [1] [AppStarter]:I: TONIDO_CUSTOM_MHTONS = TONIDO_CUSTOM_MHTONS
19:14:03:009 [1] [AppStarter]:I: TONIDO_LOW_POWER_CPU = TONIDO_LOW_POWER_CPU
19:14:03:009 [1] [AppStarter]:I: TONIDO_SINGLE_TRANSCODING_PROCESS = TONIDO_SINGLE_TRANSCODING_PROCESS
19:14:03:009 [1] [AppStarter]:I: TONIDO_REQUIRE_PLUGADMIN_PWDCHANGE = TONIDO_REQUIRE_PLUGADMIN_PWDCHANGE
19:14:03:009 [1] [AppStarter]:I: TONIDO_REQUIRE_VERIFY_LICENSE = TONIDO_REQUIRE_VERIFY_LICENSE
19:14:03:009 [1] [AppStarter]:I: TONIDO_FREE_WEBSHARE_PRO = TONIDO_FREE_WEBSHARE_PRO
19:14:03:009 [1] [AppStarter]:I: TONIDO_FREE_DLNA = TONIDO_FREE_DLNA
19:14:03:009 [1] [AppStarter]:I: TONIDO_READ_DISKUSAGE_PERIODIC = TONIDO_READ_DISKUSAGE_PERIODIC
19:14:03:009 [1] [AppStarter]:I: TONIDO_EMBEDDED_DEVICE = TONIDO_EMBEDDED_DEVICE
19:14:03:010 [1] [AppStarter]:I: TONIDO_LOAD_ADMINPLUGIN = TONIDO_LOAD_ADMINPLUGIN
19:14:03:010 [1] [AppStarter]:I: TONIDO_ALLOW_GUEST_PROFILE_ACCESS = TONIDO_ALLOW_GUEST_PROFILE_ACCESS
19:14:03:010 [1] [AppStarter]:I: TONIDO_ENABLE_OPENID_LOGIN = TONIDO_ENABLE_OPENID_LOGIN
19:14:03:010 [1] [AppStarter]:I: TONIDO_USE_UNIVERSAL_FILE_MONITOR = TONIDO_USE_UNIVERSAL_FILE_MONITOR
19:14:03:010 [1] [AppStarter]:I: TONIDO_ENABLE_SINGLE_CACHE_DB = TONIDO_ENABLE_SINGLE_CACHE_DB
19:14:03:010 [1] [AppStarter]:I: TONIDO_USE_CUSTOM_NETWORK_NAME = TONIDO_USE_CUSTOM_NETWORK_NAME
19:14:03:010 [1] [AppStarter]:I: TONIDO_ALLOW_NEWACCOUNT_RECOVERY = TONIDO_ALLOW_NEWACCOUNT_RECOVERY
19:14:03:010 [1] [AppStarter]:I: TONIDO_SET_CUSTOM_FILE_PERMISSIONS = TONIDO_SET_CUSTOM_FILE_PERMISSIONS
19:14:03:010 [1] [AppStarter]:I: TONIDO_CUSTOM_FILE_PERMISSIONS_USER = TONIDO_CUSTOM_FILE_PERMISSIONS_USER
19:14:03:010 [1] [AppStarter]:I: TONIDO_CUSTOM_FILE_PERMISSIONS_GROUP = TONIDO_CUSTOM_FILE_PERMISSIONS_GROUP
19:14:03:010 [1] [AppStarter]:I: TONIDO_NO_LOCAL_ROOTS = TONIDO_NO_LOCAL_ROOTS
19:14:03:010 [1] [AppStarter]:I: TONIDO_DISABLE_RELAY_IF_INACTIVE = TONIDO_DISABLE_RELAY_IF_INACTIVE
19:14:03:010 [1] [AppStarter]:I: TONIDO_USE_RELAY_INACTIVEHOURS = TONIDO_USE_RELAY_INACTIVEHOURS
19:14:03:010 [1] [AppStarter]:I: TONIDO_DISALLOW_GUEST_MANAGEMENT = TONIDO_DISALLOW_GUEST_MANAGEMENT
19:14:03:010 [1] [AppStarter]:I: TONIDO_EXTERNAL_GUEST_ACCOUNTS = TONIDO_EXTERNAL_GUEST_ACCOUNTS
19:14:03:010 [1] [AppStarter]:I: TONIDO_GENERATE_ROOT_LIST_XML = TONIDO_GENERATE_ROOT_LIST_XML
19:14:03:010 [1] [AppStarter]:I: TONIDO_EXTERNAL_SHARES_OEM1 = TONIDO_EXTERNAL_SHARES_OEM1
19:14:03:010 [1] [AppStarter]:I: TONIDO_EXTRA_PATH_FILTER = TONIDO_EXTRA_PATH_FILTER
19:14:03:011 [1] [AppStarter]:I: TONIDO_STARTUP_INIT_OEM1 = TONIDO_STARTUP_INIT_OEM1
19:14:03:011 [1] [AppStarter]:I: TONIDO_TONIDOPRO_NAME = "Tonido"
19:14:03:011 [1] [AppStarter]:I: TONIDO_NO_WSTRING = TONIDO_NO_WSTRING
19:14:03:011 [1] [AppStarter]:I: TONIDO_NO_MP3_TRANSCODING = TONIDO_NO_MP3_TRANSCODING
19:14:03:011 [1] [AppStarter]:I: TONIDO_NO_INOTIFY = TONIDO_NO_INOTIFY
19:14:03:011 [1] [AppStarter]:I: TONIDO_NO_SIGNAL_HANDLER = TONIDO_NO_SIGNAL_HANDLER
19:14:03:011 [1] [AppStarter]:I: TONIDO_ALLOW_LOGIN_WITH_OEMTOKEN = TONIDO_ALLOW_LOGIN_WITH_OEMTOKEN
19:14:03:011 [1] [AppStarter]:I: TONIDO_ALLOW_GUESTMANAGEMENT_LOCAL = TONIDO_ALLOW_GUESTMANAGEMENT_LOCAL
19:14:03:011 [1] [AppStarter]:I: TONIDO_ALLOW_CURRENTPROFILE_DELETE = TONIDO_ALLOW_CURRENTPROFILE_DELETE
19:14:03:011 [1] [AppStarter]:I: TONIDO_NO_CRYPTOPP = TONIDO_NO_CRYPTOPP
19:14:03:011 [1] [AppStarter]:I: TONIDO_MONIT_HDDTEMP_PERIODIC = TONIDO_MONIT_HDDTEMP_PERIODIC
19:14:03:011 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIAALBUMART = 1
19:14:03:011 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIAMETADATA = 1
19:14:03:011 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIAMETADATA_DURATION = TONIDO_ENABLE_MEDIAMETADATA_DURATION
19:14:03:011 [1] [AppStarter]:I: TONIDO_ENABLE_EDITMODE_SUPPORT = TONIDO_ENABLE_EDITMODE_SUPPORT
19:14:03:011 [1] [AppStarter]:I: TONIDO_ENABLE_POPEN_PROCESS_SUPPORT = TONIDO_ENABLE_POPEN_PROCESS_SUPPORT
19:14:03:011 [1] [AppStarter]:I: TONIDO_PREPARE_VIDEO = 1
19:14:03:011 [1] [AppStarter]:I: TONIDO_ENABLE_MEDIASCREENSHOT = 1
19:14:03:012 [1] [AppStarter]:I: TONIDO_ITUNES_SYNC_PLAYLIST = TONIDO_ITUNES_SYNC_PLAYLIST
19:14:03:012 [1] [AppStarter]:I: TONIDO_INDEXING_ENABLED = 1
19:14:03:012 [1] [AppStarter]:I: ---------------------------------
19:14:03:081 [1] [AppStarter]:E: Unable to lock file. Check if another process is already running
19:14:03:282 [3] [Dispatcher]:E: No Message Handler Found For EventNotifierService for operation SIGNALEVENT
19:14:03:283 [3] [Dispatcher]:E: No Message Handler Found For EventNotifierService for operation SIGNALEVENT
19:14:04:283 [0] []:E: PluginManager: Plugin Stop for unknown plugin
20:06:23:575 [21] [TCPServerConnection (default[#7])]:E: getZipFile Exception reading theme/resources/images/slate/progress/progress-bg.gif
20:14:00:096 [5] [UserManager]:E: Failed to load SyncServer translations
20:49:33:239 [7] [DeferredDispatcher]:E: onAddTorrentURL Exception [Host not found] caught
20:51:03:083 [7] [DeferredDispatcher]:E: onAddTorrentURL Exception [No address found] caught
20:56:42:785 [7] [DeferredDispatcher]:E: onAddTorrentURL Exception [No message received] caught
22:35:22:688 [43] [TCPServerConnection (default[#26])]:E: URL Handler not found for /shares/
22:40:36:061 [6] [Dispatcher]:E: Token not found in List: 0f5a546f-4dff-4cf4-bcf8-46ee6af545f7
