Bjornemann
Nov 21, 2013Aspirant
torrenter - Simple tool for downloading torrent files from a
Hi guys!
Just wanted to share a short application I wrote to download torrent files from an RSS-feed and store them to a directory. I've used Automatic to download torrents from showrss.karmorra.info and store them in a directory Transmission listens to. Lately I found out that Automatic isn't doing the job anymore, so I decided to write my own substitution in go. It is a tiny application that checks the RSS-feed you give it every n seconds and downloads any new torrents found. These are stored in a directory you specify, hopefully the same one that Transmission listens to.
Check out the source code at https://github.com/fjukstad/torrenter and try it out on your ReadyNas! I'm been running it for a short week now, and it hasn't caused any trouble yet.. Please note that I wrote this piece of software in a night, so submit any issues to the github repo and I'll have a look!
Cheers,
Bjørn
Cheers,
Bjørn
- delhuxAspirantThanks. I am in the same situation you were. I am trying to get this installed now (not sure I have go installed properly, yet).
I noticed the notes indicated this is only functional with magnets. Is that accurate? Will it not function with torrent files? - BjornemannAspirantHi,
It's correct that it will only work with magnets, since it's what http://showrss.info/ is using in their RSS-feed. If you'd like me to add support for another feed, just post it and I'll see what I can do!
Bjørn - mannynzTutorHi Bjørn,
Is your app still available?
Thanks! - BjornemannAspirantHi! I made the repo private, but send me a pm with your e-mail and I'll send you the source code.
Bjørn
