McFlyDK's avatar
McFlyDK
Torrent Downloader?
Hi guys.
I've just purchased a XR700, and have connected an USB HDD to the USB 3.0 plug. I want to run a torrent downloading tool on the router, for downloading to the USB (like Transmission on other Netgear routers and Downloadmaster on ASUS routers).
Where do I find this option in the XR700 (DumaOS)?
Also: How do I customize the content on the Dashboard? (I accidently removed the WiFi window, and can find anywhere to restore it)
Thanks in advance.
  • schumaku's avatar
    schumaku
    McFlyDK wrote:
    I want to run a torrent downloading tool on the router, for downloading to the USB (like Transmission on other Netgear routers and Downloadmaster on ASUS routers). Where do I find this option in the XR700 (DumaOS)?
    No such feature on the Netgear Pro Gaming routers I'm afraid.
    McFlyDK wrote:
    Also: How do I customize the content on the Dashboard? (I accidently removed the WiFi window, and can find anywhere to restore it).
    Start with the "Pin" icon .... FMI DumaOS Optimal Settings Guide: Dashboard, Network Monitor and Device Manager
    • McFlyDK's avatar
      McFlyDK
      Thanks very much for the quick reply!
      Do you know of any "workaround" to use the router to download torrents to USB?
