ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone, this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on. Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=39078...
cosmos1
Apr 23, 2013Aspirant
I have not done it, but guess the way to do it would be the following. First, enable SSH root access (see caveats about warranty though) on your netgear. Disable transmission from the web interface. Then ssh to the netgear box and edit the settings:
... to enable authentication as per https://forum.transmissionbt.com/viewto ... 362#p35883
Save the file and then re-enable transmission from the web interface.
vi /transmission/settings.json
