ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone, this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on. Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=39078...
Forage
Dec 14, 2013Apprentice
Danamian wrote: It seems like my download speed is limited to ~300 kb/s while when im using µtorrent it gives me around 5-10 mb/s on my desktop.
The two obvious reasons that come to mind:
- The port you are using is not opened in your router.
- You have set a speed limit in the transmission settings.
If the first if the case: check the transmission (network tab) and router settings and make sure that the port set in the transmission settings is open on your router. If not, either change the port to a port you already opened and forwarded on your router or open and forward the new port on your router. Note that using the same as µTorrent (if you use a specific port instead of uPnP in the first place) might not work since that port might be forwarded to a specific IP address (i.e. your desktop PC) on your router.
If the second is the case: change/disable (speed tab) the speed limit.
