ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone, this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on. Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=39078...
MrBlond
Feb 27, 2014Aspirant
Hi I have a question relating my readynas 102 regarding transmission. I hope this is the right place for it.
First i used xraid2 with one disk. I installed transmission then on the one disk and transmission worked fine.
A couple of days later i switched to flex-raid and added another disk. Now i have 2 disk in the nas with 2 separate volumes in JOBD mode.
Now transmission doesn't work correctly anymore. I can access transmission, i can add torrent files and they start downloading. However, everytime the torrent reached the 4MB point the download fail. It says no such directory. I have tried changing the download path in the settings to accomodate the change. I can also see a folder and a file being created in this folder. So I assume the folder settings are set correctly.
I have tried setting it to several different folders, i have uninstalled and installed the service several times, i have tried different torrents to see if it was a torrent error. I have also tried to set transmission to download to an externa fat 32 disk to be able to determine if it's a folder permission issue(fat32 apparantly doesn't have a permission structure). All without succes, i don't really know what to do anymore. Any suggestions?
