KgOlve
May 08, 2012Aspirant
Transmission installation problem
Hi, I've got a Netgear Ultra 2 NAS, and am trying to install Transmission BitTorrent client. However earlier on when i tried it had a "Failed installation" for some reason. Nothing appeared in the...
WhoCares_
May 09, 2012Mentor
KgOlve wrote: Alright, i entered the two command lines separately, but i got no confirmation of any kind, am i supposed to get one?
No. That's Linux, after all. So there's no chatty "Yes? No? Maybe? Maybe not?" requesters all over the place :-D
KgOlve wrote: If not then i'll move on to trying to reinstall transmission.
Go, do that ;)
KgOlve wrote: Also, when i first installed transmission (I had it installed once first before i uninstalled it and tried installing it again when the problems started occur) i had a hard time installing it and starting it. The loading indicator just kept loading for hours without anything happening, both when trying to install it and start it. Due to various happenings/coincidences it eventually installed and eventually started. Other add-ons i've tried install, start, and stop almost instantly, so it seems very odd.
Sorry, can't help you there for I don't know the internal workings of that add-on.
-Stefan
