anakha1
Mar 31, 2012Aspirant
Transmission "No such file or directory"
I'm starting to get very frustrated with Transmission (although probably I should get frustrated with myself for being too stupid to understand what I'm doing wrong). I'm using Transmission on an Ultr...
JarnoG
Mar 31, 2012Guide
After creating the share "Torrent", did you make a folder in it called "Incomplete" and then set ownership and permissions for that folder too? To see if it has something to do with the incomplete dir, you can also disable it.
