anakha1
Mar 31, 2012Aspirant
Transmission "No such file or directory"
I'm starting to get very frustrated with Transmission (although probably I should get frustrated with myself for being too stupid to understand what I'm doing wrong). I'm using Transmission on an Ultr...
anakha1
Thank you very much, JarnoG! I disabled the incomplete dir and now it works!
I had wrongly assumed that setting permission for a share or a folder means (sub)folders within that share or folder get the same permission settings unless you manually change them. Didn't realize it works the other way around. As said, unfortunately I'm not Linux-literate... :(
