zimm
Jan 18, 2012Aspirant
Transmission: Permission denied
Hi, when i try to download using transmission, is starts to download for a few seconds, then it gives me "error: permisson denied (\c\media\BitTorrent.......) ive done a bit of searching here but n...
zimm
Jan 19, 2012Aspirant
hurray! now it works.
i restored it to factory and then tried again.
i dont know if it has anything to do with it but i couldent restore to factory via frontview, it asked me to type "FABRIK" (swedish for factory) to restore but when i did it said "canceld restore" :/. so i ripped the disk out and put it in my pc then removed all the partitions :P.
so after i started over and made all my settings it worked.
my guess is that something messed up my settings, i noticed in the log that it had failed several updates (checksum something, cancelld).
thanks guys for all your help i might install the beta radiator anyway if that fixes a lot of problems, so far the reliability of my readynas isent that high (24 h between formatting).
now im going back to moving files to the nas :)
