Vatoe
Jul 08, 2012Aspirant
Transmission wont start (or any other torrent client)
I wanted to try out RuTorrent, so Installed the necessary PHP and rUtorrent service, but, I couldnt get to work for some reason- connection issues. I then gave up and thought I would go back to transm...
absincog
Jul 19, 2012Aspirant
I posted this another thread but this seems much more appropriate: I previously had Transmission 2.60.02 working perfectly on an NVX. I had installed the add-on several years ago and had upgraded through new versions with no issues.
I just re-installed v2.60.02 after "factory resetting" and rebuilding my NVX (not by choice; volume went bad in an unrecoverable sort of way). I am running the latest firmware (4.2.21). When I try to enable Transmission after installing it, I receive the following message, "Transmission service failed to start." I have not made any changes to the settings.json file.
I've uninstalled and reinstalled the add-on several times and have tried to start in several times in succession. I also reinstalled the NVX firmware. Still no luck.
Any ideas??
Any ideas??
