AllWin
May 25, 2012Aspirant
TransmissionBT 2.52 (arm) [SOLVED]
I hope this is right place to post about a bug i've found in latest TransmissionBT. When uninstalling this add-on there's a question if you want to keep your current settings, if you answer "no damn i...
AllWin
May 29, 2012Aspirant
Finally i've found the cause of these issues (thanks mdgm for some hints!). It's a character "&". Place it anywhere in settings.json and this file will get corrupted.
My original post - viewtopic.php?f=23&t=63497#p355933
Temporary solution: do not use "&" character :D
