AllWin
May 25, 2012Aspirant
TransmissionBT 2.52 (arm) [SOLVED]
I hope this is right place to post about a bug i've found in latest TransmissionBT. When uninstalling this add-on there's a question if you want to keep your current settings, if you answer "no damn i...
AllWin
May 29, 2012Aspirant
Thanks for quick update, but... At least for me 0.3.5 is even worse, unfortunately. Now all settings are squashed into one line and still it ends before "&" character. Also uninstalling add-on won't remove settings.json file. Could anyone else confirm same?
