AllWin
May 25, 2012Aspirant
TransmissionBT 2.52 (arm) [SOLVED]
I hope this is right place to post about a bug i've found in latest TransmissionBT. When uninstalling this add-on there's a question if you want to keep your current settings, if you answer "no damn i...
WhoCares_
May 29, 2012Mentor
Now that's strange for I tested it on two different systems and it worked as expected. Did you edit the settings.json manually on the command line?
-Stefan
-Stefan
