AllWin
May 25, 2012Aspirant
TransmissionBT 2.52 (arm) [SOLVED]
I hope this is right place to post about a bug i've found in latest TransmissionBT. When uninstalling this add-on there's a question if you want to keep your current settings, if you answer "no damn i...
AllWin
May 29, 2012Aspirant
Just went to Dashboard, clicked on Transmission icon, disabled it (stopped service), then clicked on button "Edit settings.json". Once finished editing saved file and started add-on again, then i got "Service failed to start". But if i login to ReadyNAS with SSH download/edit/upload seetings.json then everything works as expected... Looks like i'll have to perform "factory reset" then :?
