AllWin
May 25, 2012Aspirant
TransmissionBT 2.52 (arm) [SOLVED]
I hope this is right place to post about a bug i've found in latest TransmissionBT. When uninstalling this add-on there's a question if you want to keep your current settings, if you answer "no damn i...
WhoCares_
May 29, 2012Mentor
Huh? No, don't. Wait for 0.3.6 - I found an edge case where the config may not be deleted which may have caused your problems. 0.3.6 will be ready in 5 minutes or so.
-Stefan
-Stefan
