AllWin
May 25, 2012Aspirant
TransmissionBT 2.52 (arm) [SOLVED]
I hope this is right place to post about a bug i've found in latest TransmissionBT. When uninstalling this add-on there's a question if you want to keep your current settings, if you answer "no damn i...
AllWin
May 29, 2012Aspirant
May i ask for a link?
viewtopic.php?f=147&t=59101
"Current Version: 2.52 v0.3.5"
http://readynasxtras.com/readynas-arm-a ... ission-arm
"Version: 0.3.4"
EDIT. Never mind, found it - readynasxtras.com/addons/files/arm/TransmissionBT_2.52-arm-0.3.6.bin
EDIT 2: Sorry, still the same as on v0.3.5.
EDIT 3: No, not the same. Now when removing add-on, settings.json is being removed also.
"Version: 0.3.4"
