DRCB
Jul 28, 2016Aspirant
Twonky serial number failed
Hi, I have a ReadyNas NV+ and recently replaced all the disks but I'm now getting asked for a Twonky serial number which previously already entered for me. I can't find any contact info for Twonky - ...
JennC
Jul 28, 2016NETGEAR Employee Retired
Hello DRCB,
Twonky is an add-on and all data and settings are saved to the disks. You should have a copy of this SN, or you can contact Twonky support to ask if there is a way to retrieve SN that you have used with your Twonky account.
Welcome to the community!
