neildhunter
Jan 03, 2014Aspirant
Twonky Update for Pro 6?
Hi, Is there an update for twonky for the pro 6 on the cards? The last version doesn't handle iTunes downloaded media or playlists whilst the latest PC version seems to have this sorted. It'd be nice...
Kivas
Hi,
the PRO6 has got the same codebase like the NVX, or ?
Then u can use the latest Twonky build 7.2.6-2 . Their download library provides direct builds for the 386, 686 and x86 64bit CPUs.
If u have installed the latest version provided by super-poussin you can directly overwrite the files with the new version. worked for me - 7.2.6-2 is now running stable since last weekend on my NVX.
See my posting a few topics below : viewtopic.php?f=36&t=74540
Regards
Kivas
Regards
Kivas
