BrentDynamics
Dec 11, 2016Tutor
Unable to resome Backup Job from an old backup point.
The Setup SITE ONE: Site one is the main operating location of a business that has a RN102 connected to the the local network and readycloud as well replicate SITE TWO: Site two is the remote ...
FramerV
Dec 16, 2016NETGEAR Employee Retired
Hi BrentDynamics,
Just wanted to verify if the back-up is still running or is it done?
BrentDynamics
Dec 16, 2016Tutor
Yes the Backup has completed it transferred 93gb over 15 hours.
I can say that I have ahd several successful incromental backups that have been successful.
Still haveing the issue with the VPN
Sometimes it Connects under Windows via VPN and other times (most of the time) it says VPN Disconnected
- FramerVDec 17, 2016NETGEAR Employee Retired
Hi BrentDynamics,
Thanks for confirming and its good to hear that the back-ups went through. I am afraid I will not be of much help on the VPN side.
- BrentDynamicsDec 17, 2016Tutor
I will open a new thread in regards to the VPN disconnected issue and go from their,
I have a feilling it maybe the router casing issues ad it is in my opinion a low end low quality router.
Brent
- FramerVDec 18, 2016NETGEAR Employee Retired
Hi BrentDynamics,
Thanks and feel free to open a thread anytime.
To close the topic, please mark the appropriate post as an "Accepted Solution".
