cybermandeepsin
Mar 16, 2013Follower
Unable to view jpg from ipad
On the ipad I have the RN Remote app and can successfully connect to the Nas and view the files. I am unable to view jpg files or even download them to the ipad. Is there anything I need to do, in or...
cygenerator
Apr 24, 2013Aspirant
Same problem with iPad app version 1.5.6:
I have access to my readyNAS Duo v2 and can see the shares and even the files in there. But if I want to have a preview of a file (for example of a pdf), a message in the middle of the sceen tells me that the "Preview is not available, please press the view icon at the top menu to see the contents of the file." :shock:
If I do so (pressing the small loupe in upper right corner), nothing happens. The same behaviour occurs when pressing the download button beside. :?
I don't know if it makes a difference, but this concerns only the iPad app in my LAN. The iPhone app works perfectly in my LAN environment and access from outside the LAN is also no problem.
So where might be the bug? Is it an app-related issue or do I have to change something in the settings of the NAS itself (obviously not as otherwise the iPhone couldn't get access). Is there a setting in the iPad that has to be considered???
Any help or idea would be highly appreciated!!!
