JavelinSST71's avatar
Mar 04, 2026
Unable to view/access XR1000 USB Storage in Windows Pro 11 File Explorer
Setting up a new Windows Pro 11 laptop. I want to use Windows File Explorer to view and access all folders/files within my WD External HD (connected to XR1000 through USB).
Environment Details:
* Lenovo ThinkPad running Windows Pro 11 version 25H2 (OS Build 26200.7922)
* Netgear Nighthawk XR1000 running version 1.0.0.74_1.0.63
* Western Digital Ext HDD 1021 connected via USB to XR1000
I'm trying to map a network drive in File Explorer to the XR1000 USB Storage - \\readyshare\USB_Storage.
1) Open File Explorer
2) Right Click 'Network', click 'Map Network Drive'
3) Choose Drive letter, and in 'Folder' type \\readyshare\USB_Storage and click Finish
4) A Windows Security page opens asking to Enter network credentials - User name and Password. It also states - You can't access this shared folder because your
organization's security policies block unauthenticated guest access. These policies help protect your PC from unsafe or malicious devices on the network.
- I've tried entering various Windows and Netgear user names and pwds without success
Notes:
In File Explorer under 'This PC', there is a folder XR1000. However when I expand XR1000
/Browse Folders/14TB Copy/My Documents/... it is only showing .jpg files. No text, pdf, or other file extensions, and missing some folders.
In File Explorer Under 'Network', there is an XR1000 Media Device listed. When I click on that icon it opens the XR1000 admin page.
In my previous laptop running Windows Home 11, I was able to access all the folders within \\readyshare without any issue.
How can I view and access, in File Explorer, all of the contents on the WD HDD 1021 which is connected to XR1000?
Thank you.
  • I'm back working on this issue! It appears, from all I've read, that it is a problem with a Microsoft update. I was able to finally follow the link provided by StephenB - and successfully mapped my WD hdd 1021 (through USB port on XR1000) and have access to all folders/files! Here are the steps I followed:
    1. Ran Powershell as administrator
    2. Get-SMBClientConfiguration (to verify EnableInsecureGuestLogons was set as False and RequireSecuritySignature was set as True)
    3.
      Ran the following
      1. Set-SMBClientConfiguration -EnableInsecureGuestLogons $true
      2.
        Set-SMBClientConfiguration -RequireSecuritySignature $false
    4. Restarted computer
    5. Opened File Explorer and mapped to \\readyshare\USB_Storage
    Thanks to everyone for your help and support!
    • JavelinSST71's avatar
      JavelinSST71
      Guide
      Thank you. I'm working on following your directions and will apologize up front as I'm a Grandmother working to setup this new laptop, and this is the last piece.
      I have completed the steps you provided, and also tried the solution that worked for Xuul. Unfortunately things are still as they were and I'm unable to access the folders/files on the external hard drive.
  • StephenB's avatar
    Did you try readyshare as the user name with the router admin password?
      JavelinSST71
      Guide
      Thank you. I didn't use readyshare as the user name, I will give that a try.
      Unfortunately that didn't work - still couldn't get past the Enter network credential page.
  • If you need to enter a username and password for Windows to connect to ReadyShare then on the ReadyShare page on the router you need to set the user/pass for this access method and then use that when trying to add it
      JavelinSST71
      Guide
      Thank you for the response. I have had to leave this issue for a bit and will address it in a few days.
  • I think I will purchase a Netgear support contract to help solve this issue for me, as the past two weeks my husband has been in the hospital and I haven't had the time to work on this.
    Thank you to everyone who has provided help, I really appreciate it!
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Totally understand, sorry to hear that, hope everything is okay!
