cybermandeepsin
Mar 16, 2013Follower
Unable to view jpg from ipad
On the ipad I have the RN Remote app and can successfully connect to the Nas and view the files. I am unable to view jpg files or even download them to the ipad. Is there anything I need to do, in or...
Mace_Windoo
Apr 26, 2013Aspirant
Hi cygenerator,
I reproduced the issue on an ipad. However, once re-installing the app I wasn't able to reproduce it again. Can I ask that you remove the app (uninstall) and then re-install the app again.
Also, if you are looking to view images, I also recommend using our "ReadyDLNA App" for iOS. You must enable dlna on the share for this to work and it shows thumbnails of images in your shares and streams video media aswell.
