cybermandeepsin
Mar 16, 2013Follower
Unable to view jpg from ipad
On the ipad I have the RN Remote app and can successfully connect to the Nas and view the files. I am unable to view jpg files or even download them to the ipad. Is there anything I need to do, in or...
cygenerator
Apr 26, 2013Aspirant
Hi Mace Windoo,
I tried the steps you suggested, but the result is disappointing, because I didn't get the expected success. :(
First of all, I removed the remote app, restarted the iPad and the re-installed the app - same situation: no preview for pdf and jpg-files and also no possibility to download them. Then I installed the readyDLNA app, to see what's the status on viewing jpg-files. Result: the app tries to get a connection since minutes and isn't obviously able to establish it (the NAS itself is connected in the app, but the access to the folder(s) is (are) not possible).
On the other hand I'm glad that at least once you were able to reproduce the problem. So you could get an impression how annoying this issue is.
What could be the next step? Is there anything else you'd suggest to check (maybe also inside my LAN/NAS/iPad) or do you need some more informations/descriptions?
