greee
Jul 18, 2012Aspirant
update of Ajaxplorer soon ?
A new version of Ajaxplorer is out from some days (version 4.2.0 out 24/06/2012) Will there be an update of super poussin add-ons soon ? or is it possible to install it directly on readnas (with bot...
kwalnut
Aug 08, 2012Aspirant
im trying to upgrade, downloading the upgrade file work, but when checking folder permissions i get Error : The root install path is not writeable, no file will be copied! The archive is available on your server, you can copy its manually to override the current installation.
Can someone tell me which folder i need to make writebale?
