geoff_sim
Oct 13, 2009Aspirant
USB Webcam and Motion add-on
Webcam support on the DUO Download UVC Video Drivers Download Motion Application Video drivers has been tested on arm ReadyNAS with RAIDiator 4.1.10 UVCVideo is the magic behind it all, and ...
mdgm-ntgr
Nov 06, 2009NETGEAR Employee Retired
Other things you should mention are what firmware you tested it on (know it works on), minimum RAIDiator firmware required...
Also any other add-ons required to be installed for it to work and what hardware e.g. which usb webcam you tested it with and what range you expect to work. You can take a look at the Community Add-ons forum to see what information you should provide to help inform those who may wish to test your add-on.
Basic instructions on how to use, could also be useful.
