ScottWay's avatar
ScottWay
Webcam streaming issues
I am having issues with streaming webcams from a university campus. These stream perfectly from every location I visit with my computers and phones:  coffee shops, work place, other peoples homes. They stream fine over cellular data as well.
However, none of my devices will stream these cams at home on my wifi using my Orbi. I have disabled all parental controls. I have latest firmware.
I do not have issues with other webcams, at least I have never encountered any issues and I stream a lot.
https://www.mtu.edu/webcams/campus/
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What devices do you have that you use to stream from these cameras?
    What is the size of your home or apt? Sq Ft?
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • ScottWay's avatar
      ScottWay
      I have firmware V2.5.0.38
      I have a Spectrum modem PC15
      Orbi is in Router mode.
      I have a 3000 sq ft house and the two satelites are approx 30-40 ft from the base, but the devices all connect to the base (a whole other problem).
      All devices have trouble in my home with thsi particulr sites webcams., Android phones, Lenovo desktop, Dell laptop.
      Settings are:
      WIRELESS SETTINGS (GENERAL)
      Region North America
      2.4G Channel Auto ( 7 )
      2.4G Mode Up to 400 Mbps
      5G Channel 36+40+44+48(P)
      5G Mode Up to 866.7 Mbps
      All these are enabled:
      Enable Daisy-Chain Topology
      Explicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
      Enable MU-MIMO
      Enable Fast Roaming
      I will try disabling a few of the settings you mention. I have tried these in the past but will again.
      • tomschmidt's avatar
        tomschmidt
        Virtuoso
        ScottWay, you are running v2.5.0.x firmware, and it was retracted by Netgear after many bugs were found.  NG disabled autoupdate in recent releases due to the issues that it has caused.  I suggest manually upgrading your RBR50 and RBS50 to v2.5.1.8 available from https://www.netgear.com/suppzio fort/product/RBK53.aspx#download
        1. Backup your settings of the RBR50 router (in case you need to restore or revert)
        2. Download the zip file for both the RBR50 router and RBS50 satellite
        3. Unzip the files
        4. Manually upgrade the firmware on the RBS50 satellites first using the RBS-v2.5.1.8.img file
        5. Finally, upgrade the firmware on the RBR50 router using the RBR-v2.5.1.8.img file
        Settings are:
        Enable MU-MIMO
        Enable Fast Roaming
  • CrimpOn's avatar
    CrimpOn
    LOVE the campus webcams. (They stream fine on my Orbi RBR50.)   Would it be OK to ask which web browser is being used to stream these cams?  (on which platforms?)
    I would be sort of shocked to think that Disney Circle could ever find these streams objectionable.
    As FURRYe38 pointed out, that particular firmware has been "disgraced" and users are encouraged to update to 2.5.1.8.  I sincerely doubt that the Orbi firmware is the cause of this specific problem, but there is no sense remaining on firmware with "known issues" of any kind.
    Could you explain more about "what happens" when you attempt to stream these feeds?
    • ScottWay's avatar
      ScottWay
      Yes the cams are great. I watch my son play broomball.
      I use Chromium Edge browser on win10. Chrome on Android. I have Circle disabled.
      • ScottWay's avatar
        ScottWay
        Forgot to mention..the adobe module loads and the stream tries to start but just circles. Never loads and times out.
