geoff_sim
Oct 13, 2009Aspirant
USB Webcam and Motion add-on
Webcam support on the DUO Download UVC Video Drivers Download Motion Application Video drivers has been tested on arm ReadyNAS with RAIDiator 4.1.10 UVCVideo is the magic behind it all, and ...
geoff_sim
Nov 11, 2009Aspirant
Yes, thats right :-)
It does not support all webcams, but quite a lot as you can see.
The GSPCA add-in will create a /dev/video device that can be used by most camera applications, still or motion.
When you plug in your webcam, the add-on will show if it has recognised the camera.
The Webcam add-in is a simple add-in that has been set-up to capture an image every 5 seconds, and I have created a simple web page in /c/media/webcam to display the image.
You can modify the html as you see fit, and the webpage will be accesible via the address <your-ip-address>/webcam.
I use a dyndns account that redirects to my router (supports dyndns) .
My router then redirects a specified port to my readynas, and this allows me to view the page from, say, work.
I am thinking about creating a plugin for "motion", but that requires quite a lot of extra apps to be installed.
